Old 07-04-2007, 10:58 AM
J Persons J Persons is offline
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
Your problem is probably the firewall mounted Holley regulator. Try moving it to a location in front of the engine where it won't see as much radiant heat. You could also install an electric pump near the tank to give the mechanical pump a little help.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
