I made my last gaskets out of laminated aluminum from McMaster. It's .002" aluminum layed to .048". I cut a piece (6"x6" + -)and laid it on the side pipe flange. I use an awl to mark the out side and a transfer punch to mark the holes. Cut and drill. I also have tried the red hi-temp silicon with some success. I did use the hi-temp silicon with the new gaskets. Over 2000 miles and no leaks. I have tried Mr Gasket gasket, industrial gasket and several other gaskets. Most I blew out with in hours. The red hi-temp silicon last several months. I can sell you 2 pieces from the sheet that I bought. Cost about $4 each. Tell me the size you need if your interested in making your own.
Dwight
algunruner@aol.com
http://www.mcmaster.com/
Material Easy-to-Form Electrical Grade Aluminum (Alloy 1100) and Extra-Strength Aircraft-Grade Aluminum (Alloy 2024) and Corrosion-Resistant Marine-Grade Aluminum (Alloy 5052)
Finish/Coating Unpolished (Mill)
Type Laminated
Thickness .048"
Length 24"
Width 24"
Tolerance Standard
System of Measurement Inch
Material Certification Without Material Certification
Application Shim Stock
Specifications Met Not Rated
Laminated Layer Thickness
.002" | .003"
These 2 products match your selections
Laminated Layer Thickness Each
.002" 9574K17 $48.37
.003" 9574K32 56.07
