Hi Merv
The VDO gauges are about $750 .00 and you can have the pointer painted out and chrome bezels fitted which would add about $180.00 . What i like about the VDO speedo isthat it can be calibrated at will in the cockpit . The smiths will need a power supply to the fuel gauge and the water and
oil will need a voltage regulator .
With the reverse light see if the MGB lights still comply , i have used the Ford Au Ute light cut into the body . Make sure the reflectors are also ADR ther getting very picky . The Motor Litor wheel is also a none ADR compliance part so if you like one fit it after .
Have Fun from RAW
