So, if I understand, the hydraulic line that runs from the master cylinder to the slave cylinder is a rubber hose, that is held on to the outlet fitting with a hose clamp? Can you post a picture, usually that line is metal tubing or a compression fitting with copper, brass or stainless tubing.
