Originally Posted by lineslinger
If you install the sandwich adapter between the block and the oil filter on your engine, as the engine is configured in the last picture, you will be extending the total length from block face to end of filter an extra 1-1/4". The adapter can be mounted and sealed any direction you want the outlet and inlet fittings to point, with the actual fittings being rotated within the adapter to suit your specific needs. There should not be any interference other than the close exposure to the header pipes which looks like they would heat up the filter itself quite a bit, but hell, thats the way they designed it.
Is that car front wheel drive?
The only place the fittings can come out is toward the bell housing. I had the exhaust manifolds ceramic coated inside and out, in addition to ceramic coated heat shields.
Originally Posted by Jamo
I know you don't want to use a remote, but you're fighting against yourself. I owned a SHO (certainly not built to where yours is ), so I have a fairly good idea of what you're dealing with, as I'm sure Sal does.
I never did like that filter where it sat...put it up there with the windshield water bottle. It's all reversible if that's a concern, and I think it would compliment your engine compartment.
KISS
JMHFO
I have a supercharger in the stock water bottle location... The bottle had been modified to fit on the other side, and a water injection accumulater will be mounted over there too. I used to have an
AMSOIL remote/bypass filter (2 filter - 1 bypass, 1 full flow) and I didn't like it. I lost all kinds of
oil pressure which I think helped aid in a spun bearing.
Bat/Mocal makes spacers and Eric at Bat may have a small spacer for me. I just need 1" or so to give clearnce, but not extend the filter too much. I REALLY do not want a remote filter.
I don't really like the location either, but it's not difficult to change and I don't drive it too much, so there's not too many
oil changes needed.
