Old 07-09-2007, 10:35 AM
Traveller Traveller is offline
Cobra Make, Engine: ERA, Ford 428 SCJ
Default Primary and Side Pipe Install
I believe I have everything done correctly.
1) Holes Cut
2) Primaries and Pipes Installed (that was a ***
I'm about to weld the hangers and brackets but I have some questions about clearence.
First, should I tighten up the primaries to the heads before I weld?
#3 primary pipe is up against the foot box. Since I'm pulling the motor after I've completed the pipes, I could create some clearence through "surgery". I guess I just looking for back up.
#2 has 1/16" (maybe less) of clearence between it and the stearing U-Joint. I could put a stategic "dent" in that pipe, again, I'm looking for some back up before I do that.
In general I'm surprised how well everything is fitting considering I'm retrofiting current components to a 25 year old car.
Would pictures help?
