07-10-2007, 05:55 AM
Mi
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
you might also have boiling brake fluid due to what you are using in addition to the routing of your lines .
if you are using DOT3 fluid , it will boil earlier than other fluids . consider changing to a DOT4 or other that has a higher boiling point . available at your auto parts store . DOT 5 is not usually recommended for cars driven vigorously but is commonly used on non high performance show cars . If you change be sure to flush old out before new in . Bill
