Old 07-10-2007, 06:58 AM
onefastmustang's Avatar
onefastmustang onefastmustang is offline
Cobra Make, Engine: CRII with a Stroked Windsor
Originally Posted by strictlypersonl
There's no way for the system to build up pressure if the free play is correct and the master is not defective.. When the pedal is "un-pushed", there's a return port in the master which will remain open to bleed fluid back into the reservoir.
could my wildwood proportioning valve be causing this issue in any way??
