Originally Posted by BEB
What does that mean in English?
Don't know what slip angles are. Just want to know do I add air or take some out???
Stricklypersonl was saying that if the front end has lost traction, understeer, you have exceeded the slip angle for that end. So, you want to make a change to lower the slip angle on the end that is not working (or you could increase the slip angle on the other end)
So........
Increased tire pressure > lower slip angle
stiffer springs or anti-sway bar > higher slip angle
More negative camber (within reason) > lower slip angle
This of course is hugely simplified and many, many, many factors (including the one behind the steering wheel) play into a balanced car which is what you seem to be trying to achieve by reducing understeer. Remember, understeer is safer. Most of our cars you can change from under to neutral to over with the right foot.
Now, forget all that junk and tell us about having your Cobra on Nurburgring
Pictures? Video?
