Windscreen
On my B&B the weatherstrip is tighter on the sides than in the middle, I would think there should not be a gap between the seal and the body. I do know that if you stand the window up the seal is about even pressure along the whole length. If you rake the top of the windscreen back, then the center starts to lift off the body. Now with that said, If you stand the windshield up as to have the even pressue , the profile looks are just not there, I raked mine back to a happy medium between seal contack and decent looks to the angle of the windshield. You should be able to access your support arms and redrill the mounting holes. I would use caution though, especially if you have a hard top, as when you reposition the windshield, you will change the location of the top frame in relation to mating with a hardtop. Hope this helps.
