SP:
The rear bung for the
oil temp sender should fit at the rear if there is enough room between the pan and the rear engine plate.
----> Thanks for the response. How do I "confirm" if there will enough room...I guess thats my biggest fear that I have the bung installed and then when I put the engine in it hits the rails...
I think you'll find that rebuilds are from the original cores - i.e. Autolite or Ford - although I'll have to check the markings tomorrow.
----> ok, thank you.
Zoera....what amperage is correct for the altenator as there seems to be a wide choice here?
