The driveline is not in it yet. I need to have it shortened by about 1". The clutch arm coming out of the bellhousing moves about 2" when I press on the clutch pedal.
I stuck the driveline in the end of the trans and with the trans not in gear the driveline spins. With the trans in gear the driveline does not spin. When the trans is in gear and I depress the clutch pedal the driveline still will not spin. The clutch is not engaging and there is only about an inch of adjustment left. Are there different length's throwout bearings for the T-5? What do you guys think about the hydrolic (however you spell it) throwout bearings.
Terry
