Hi Terry,
I did my own install of a Roush 427 DFI and a TKO600 with 0.82 5th using the Olthoff DFI coupe install kit. I found the Olthoff kit to be just about 100% complete down to nuts, bolts and washers. You have to specify your engine as the throttle arrangement is different for a carburetored engine than the DFI engine and the drive shaft is different (slightly longer) for the five speed than the longer "standard" six speed box with its slightly shorter drive shaft. Dennis probably does have more install experience than anyone else and helped develop the car to begin with so you can't go wrong with his kit. Dennis was also a great help with information when I needed it. This doesn't mean the other kits are not as good or even better, I only know about the Olthoff kit.
Good luck and regards,
Ron Weingart
