That looks good Mike--keep me advised how it works out for you and what there company name is up here.
The ZO6 timing cover is larger to fit over the double
oil pump and takes a different Harmonic balancer then to clear the cover.
Definitely make a cover with a window for cam timing changes as it is not very easy to get the lower pulley off and on and aligning the front cover is critical
Jerry
