speedometer-smooth & accurate.now
i thought this might be of some help to anyone interested.the smiths speedo on #1739 was really starting to annoy me w/jerky operation, no confidence w/actual speed. tryed new cable, lubing, re routng for less turns, & just about everything else.
the solution was a new electronic smiths speedo # sn5346-02cb from nissonger, after some research the sender for tremec-ford#e9tz-9e731a
swapped over existing gear which was in perfect condition.unit was easily programmable, (came out of the box only off by one increment).the harness was very easy after getting wiring diarams from blas, just used existing harness for reverse switch (not bieng used) right next to starter selonoid.at dash side to left of steering coulmn un plugged junction to rear for reverse lamps, & used two wires for speedo.works like a charm, only difference in appearence is the odometer has a digital lcd.
tim
Spf #1739 Roush392 Tremec
Reason: misspelling
