Old 07-19-2007, 10:02 AM
Bluenoser Bluenoser is offline
Lightbulb Factory Five Racing Coupe Registry
Hello,
I have a Factory Five Racing Coupe Registry. I hope that F5R Coupe owners will add their information so we can share our builds.
Here are the steps to add or edit your coupe to the registry.
** ADD **
1. You have to register. Please use a real email address as a confirmation of registration will be sent to you after I have approved your registration. To speed your approval, put your frame number in the website field when registering. Make sure that you mark the check box in the "I agree.." section.
2. When you have received your confirmation, then you need to login.
3. Once you have logged in, change your profile information. Make sure you fill in your name and website if you have one. You need to do this so your name can be entered in your registry entry.
4. Select "Auto Registry" under "Main Menu" and then select the "Join the Registry" when visible.
If you want to post images with your registry, please note that you will need to have them 600 pixels in width or less. If you do not know how to shrink photos, then use this website.
http://www.shrinkpictures.com/
** EDIT **
1. Log in. Find your vehicle. There is an edit icon at the bottom of your listing.
2. Enter in the new information and select the "Post" button. If you want to add a photo or two, then press the "Browse" button and locate the file on your computer. Then select "Post" button to submit your photo.
If you have any problems, please contact me on this thread so I can provide you with a solution and others can see that solution.
Thanks
