Old 07-19-2007, 06:59 PM
coreyc coreyc is offline
Default Rear coil-over shock installation
The rear coil-over shock top mounting bracket supplied by B&B can be installed 2 ways. the tab to the rear and the bolt in the front (large hole), which looks correct or the tab in the front and the bolt in the rear (small hole) which does not look right but would keep the shock farther away from the rearend (requiring a shorter spacer at the bottom). How have you installed this mounting bracket?
Thanks,
Corey Crawley
