  #104 (permalink)
Old 07-19-2007, 07:10 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Now you need to press the old bearing onto the new (short) shaft. You need to use a tube to press the bearing on. A note here: You need to press on the internal RACE of the bearing and NOT on the rollers or the cage. If you press on the rollers or the cage something will be damaged--most likely, your WALLET!
