Old 07-20-2007, 03:57 PM
RENEW1 RENEW1 is offline
Cobra Make, Engine: Building ERA #749 427 Cobra
Default Need Opinion on Cenerforce clutch counterweights
I have been told by someone who has built many FE powered Cobras, that if you use a centerforce dual friction clutch, the centrifugal weights should be removed. Supposedly this makes shifting easier at high RPM. The opinion is that the Cobras are so light the extra pressure the weights put on pressure plate is not required. Centerforce has a warning not to remove them. Anybody had any experience one way or the other?
