Old 07-21-2007, 11:15 AM
JAC's Avatar
JAC JAC is offline
Cobra Make, Engine: Classic Roadsters II
Default Steering U-joint
Has anyone had to squeeze the split in the u-joint that goes on the pinion shaft of the rack with a vise to get the u-joint to tighten up with the bolt? The bolt will not draw the u-joint together enough to clamp on the shaft. Is squeezing it in a vise to get it close enough for the bolt to work safe? Or would it be better to use a u-joint with a set screw instead? Pinion shaft is about .012" undersize from 9/16".
Thank you
"COBRA" Big kids gokart
