Hi guys,
I have a 1964 Ford 427 FE I'm going to sell soon. It is currently at Speed O motive in Covina, CA. The motor came out of my 1975 boat. It will be replaced with a modern 460 Big block Ford. I have a small block in mine and runs just fine for me. The motor has new 428 Edelbrock Alum heads and Edelbrock RPM manifold. It has a Scat stroker crank 496 cu in, new J.E. 40 over pistons, ARP rods, HV
oil pump Comp cam, solid lifters and roller rockers, all new bearings and rings. It has been balanced with new flywheel and harmonic bal.
It will not have, timing cover, water pump, pan and Carb, all are for marine use.
Roy Pollard
roypollard@verison.com
