Timing curve
Hi,
It looks like a good plan. It probably works good like this because the MSD actually can runabout 2 to 4* more advance than you would think.
The top end retard is good also,not as hard on the rods.
I would pull the plugs and check for detonation ocasionally. Instead of tan the plugs will have a yellowish spot or actuall start burning the electrode off. If the plugs read OK I think you are set.
Perry.
