The other thing when it dies is to check the float boals and see if it there is gas in the bowls. If the fuel line collapsed and it died because of no fuel, you will not have any gas in the bowls. If there is gas in the bowls, then you know it is an ignition issue- then try partick's suggestion to check it.
Replica is not a dirty word.
