Old 07-23-2007, 05:09 PM
rcweingart rcweingart is offline
Cobra Make, Engine: SPC Brock/Shelby Cobra Daytona Coupe 51, Roush 427IR, also full custom 600+ HP Austin Healey and Ferrari Daytona spyder
There are two pans for the SPF Coupe, the original SPF supplied pan that is shallow and wide (and not terribly good at oil control) used on the early cars and the later Roush supplied pan (which is also used on the GT40 engines) that has a somewhat deeper sump for better oil control. The older style pan would hold about 12 qts including the lines and oil filter. I replaced my older pan but haven't had a chance to drain and fill my new style pan yet so I can't tell you how much it holds, probably around the same but check with Roush if no-one else knows.
