Thread: Chebby and Box
Old 07-24-2007, 02:15 AM
Rebel1 Rebel1 is offline
Originally Posted by sambo
Stiffy,
Yeah my quote for everything from fan to rear of gearbox was just under 15k. Forget the factory clutch though, get a Textralia.
Absolutely correct and the Textralia comes with a special flywheel so you wont need the standard one. Same with the internal slave cylinder.
Other bits that have been included in some packages are:
The battery power harness...not required for our cars.
The ECU mount base....not required
Don't buy the holden right hand engine mount bracket unless you are sure the chassis is set up for it. Get the Corvette one from Eagle in Sydney.
Don't get the factory belt unless you are using the holden power steering.
If I think of any more I'll post em later.
