Old 07-24-2007, 01:01 PM
Rick Parker's Avatar
The weights are there to provide additional clamping force and aid in lock up. The centrifical force generated by the spinning weights allows for (in theory) a lighter spring and for a lighter pedal at lower rpms. Sometimes the results are questionable. Without the weights the designed in clamping force cannot be created, and slipping may result, hence the previously mentioned "Warning". I personally thing a stiffer pedal is just the price you pay for a stronger clutch. No need to reinvent the wheel.
Rick
