Mild or Wild Cam?
I have a Comp Cam Hydralic Roller with the following specs:
242 - 248, .645 -.635, 112 degrees LS
I'm not sure what these values represent (from the build sheet) but I'm curious about your opinions whether this is a mild or wild cam. I can get it to idle at 900 RPMs but it "feels" like it would be happier at 1000 - 1100 as I sometime need to pump the pedal keep it idling at 900. In fifth gear, I'm doing about 2600 RPM at 75 mph and it runs great (.82 OD, 3.54 diff)! Thoughts? Thanks!
Bluedog
