Originally Posted by schleprock
IF i wanted to get a NEW distributor for some crazy reason -- there are so many to choose from -- what do YOU recommend or at least what are the options.
The MSD Pro-Billet FE Distributor.
http://www.msdignition.com/dist_22.htm You don't need a vacuum advance and you can start out with the springs and cam that come with it right out of the box. Set your timing to 32 degrees at 3500RPM for starters (don't bother setting your idle timing) and see how it runs. You can tweak it from there but you might find those settings are just fine.
