Old 07-25-2007, 10:21 AM
Default Stalling
Bluedog If your car is stalling on turns and stopping, your carb floats may need adjustment, The float levels could be too low causing this. If it is really hot under the hood, the gas could be boiling and causing the same problem. I would adjust the floats and look at the idle screws and back them out 1/4 of a turn and road test, if car runs better go a 1/4 turn more. You maybe running lean. Rick L.
