Old 07-25-2007, 12:12 PM
DAVID GAGNARD's Avatar
Mild, not in my opinion, wild, yes.......but that is only my opinion......I consider anything over 625 lift wild, but thats me, other may think it just right.....
With your cam/motor specs, I'm surpised you can get it to idle at 900 rpms, I would think it would need more like 1100 rpm idle to run right.....I have seen motors with less camshaft and other goodies than you have that would not hardly idle under 1000 to 1100 rpms.....
High lift cams do not like a very low idle, the reason your car stalls is lack of vacum at the low idle rpm........put a vacum gauge on it and you'll see what I mean........
My street car is the very definition of a mild motor and idles at 800 rpms,while pulling 17 inches of vacum, on the other hand my race motor idles at 1000 rpms and pulls about 10 inches of vacum.....if I idle the race motor down any, it will stall just as you have described...
BTW: both motors have a lot of KC components in them!!!!!!!!
David
DAVID GAGNARD
