Old 07-25-2007, 02:43 PM
onefastmustang's Avatar
onefastmustang onefastmustang is offline
Cobra Make, Engine: CRII with a Stroked Windsor
Originally Posted by CobraEd
I have this exact setup, (Classic Roadster, T5Z, King Cobra Clutch) and have been told that these throwout bearings are made to ride the presure plate all the time. It is the same way in all the 5.0 mustangs with stock clutches. So far, no problems, all works well.
My clutch engauges about 3/4" from the top where I like it to be. I have a steel sleeve that slid over the cable end that allows more adjustment. I is about 2" long. The sleve is between the clutch fork and the nut on the cable so there is way more adjustment room.
Where did you get this sleeve from?? I would like to pick myself up one to get more play..
