Old 07-26-2007, 08:58 AM
tcrist tcrist is offline
Jimi G
I barely have enough room between the pivot ball and pressure plate to slide the clutch fork through to hook it on (maybe 3/8 of an inch). I am thinking about modifing my firewall to get more throw. If I cut a hole in it, set the clutch then glass in a dome leaving clearance for the pedal then that should work. Sounds like modification time. I talked to Mustangs Plus last night and they said that the throwout bearing should not ride on the pressure plate all of the time. I am going to drop by the Ford dealer tonight and ask one of there mech's.
Terry
