thanks Bill,
Like I said, I can't get the sway bar off because the mounts are squeezed between the subframe and the vertical frame member that comes down to the gas tank rail. I spent some time today trying to work things out. I can see the help in taking out the fuel tank (sure do wish I hadn't just filled it!), it is coming out. I have begun to lower the subframe in order to remove the sway bar brackets.
...all for two bolts!
