Old 07-27-2007, 11:15 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Default Ring & Pinion Install/Swap
Hi experts,
I have done some searching but didn't find any good info. One thread looks like it had the answer but the links to other sites were no longer active.
Here goes.... I am thinking about changing my rear end gears (ford 8.8)
I am somewhat familiar with the process but concerned with the alignment- don't want a rear that wines or burns up!
Ring gear is easy I think just bold it on.
Do you change the bearing on the pinion?
There is only one way to shim the pinion correct ---in and out?
How do you check alignment and backlash? How much?
Is it worth just having someone do it or should I forge ahead and try something new?
Thanks for your input!
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
