Dwight.. That is a good IDEA. I am using the holley pressure regulater one side to carb and other side to pressure guage. Real easy to take cap off guage side and connect line to it and then to a gas can. I will check this in the morning. The thing is I had the same problem with the holley mechanical pump. Scott I know this is not an indication because of when the pressure drops the performance reflects it is starving for fuel. I even took the regulater out and had same problem. I will try and contact holley in the morning. Thanks for any help. Bermblaster
