08-11-2001, 05:14 PM
WA
Cobra Make, Engine: VICTORY, 92 C.I., belt drive, saddle bags.
Help Identify
I finally tackled a pesky oil leak at my remote oil filter block adapter. Come to find out, the hard brittle material gasket was cracked between the high pressure side and a bolt hole... therein lays the leak.
I cannot identify the adapter by brand, but it does a have a P/N of SP327 cast on the outer surface. It is installed on my 1974 Ford 390FE and is cast aluminum sporting an oil in, and oil out port with integrated oil pressure port.
Fotos attached, 1st is front view, 2nd is back view.
Can anyone help me ID this thing soze I can obtain a new gasket? Else wise.... I guess I'll be having to buy a whole new adapter, cuz my 90psi gasket making skills are nil.
Thanks to all... Zderf
[IMG]D:\Image Expert Images\LowRez\FilterAdapter.jpg[/IMG]
