Old 08-01-2007, 06:30 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Is you solenoid stuck? You mentioned it made a noise. Do you hear it extending out and retracting as you turn the key?
If all of the electrically looks good then give the starter and solenoid a tap/whack. This may help if come free of it is stuck.
You can also remove the starter and apply voltage for a see if the solenoid pops out and starter turns. Be careful the starter has plenty of torque so clap it down somehow. Only do it for a sec or two. Someone else may have a better way of testing your starter. Auto parts stores may even test it for you.
Hope that helps.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
