It helps if you lay your tape out in a daisy pattern [with all crossing in the middle] so when you pull the extra tape off you can pull it towards the center so it won't pull the paint from the newely cut edge of the hole.
I have seen a 2 in strip of paint pulled off by pulling away from the hole.
Good Luck!!!
