David, More great picture tahnks.
?: What fuel pressure regulator? Are you using the mechanical pump as well? Can you give us a plumbing sketch? Bypass fuel pump? Do we need to run a return line? Thanks keep it comming. I am gaining ground fast. Also I had to do some swearing to get the trans tunnel off- I just trimmed around the brake lever- Is that right or did I take it off wrong? I assumed I did not need to remove brake lever.
