Forgot to mention... My chassis is set up for Series 2 and takes the stock shims I mentioned in my last post. I had another look at your pic and 6mm seems a little excessive considering, mentioned, the G-Force is designed for the Jag suspension. You should only require shims for fine adjustment.
Regards
Roy
