From above, you probably have Series 2,lower arms and Series 1 uppers.Depends what you want your front track to be.the Series1 is narrower and also uses not vented rotors. I run Series 1 with not vented but I have only ever experienced fade after a lot of laps on a track. Series 1 is lighter also.It's a choice I suppose.Also the rears I used are from a 68 or there about "S" type,from the factory correct length.
1.5 degrees neg camber all around , and toe all 4 wheels in.
