Then GENTLY pry up on the back of the shift box with a pry bar. The box will lift up. It is only held down with silicon. Gently does not mean play tug-of-war with the pry bar. I assure you--you will lose. Gently means GENTLY!!! If you have to pull hard, the pry bar will slip and you will wake up staring at the ceiling (or staring at your buddies laughing at you) as you will be knocked out by the roll bar smacking you in the back of the head as you fly backwards. Also, when you wake up you will easily find the one bolt you forgot to pull out.
