Old 08-12-2001, 08:38 PM
Campy's Avatar
Campy Campy is offline
Post Assembly Lube
Hello Pat,
I hate to disagree with Dave, but the latest research on any type of assembly lube indicates that you should NOT use any moly (molybdenum) based substance. The rational is that this is a particulate that will eventually make its way to your oil filter.
Don't get me wrong, certain particulate lubes are ok. The goal is to find a substance that will completely dissolve in the motor oil once it starts to circulate.
Personally, I would stick with a commercially available assembly lube.
For what it's worth,
Paul C.
