Old 08-05-2007, 10:57 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
The 011 is the GM conversion Tremec 6 speed. I say conversion because it is configured with a mechanical speed drive not electronic and has the front plate allowing a standard scatter shield or GM bell housing
(but be aware of a 15 degree twist or rotation if not the proper plate). but you can re drill without a big problem. It has 2 shifter mount locations built into case and the up shift feature is deleted as in the electronic GM car versions.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
