no giving up here pete,just might have to settle for 260 instead but she,ll still rumble,im toying with the idea of a trailer at the moment using using irs axles which eliminates the use of leaf springs,instead using an inner and outer axle with solid rubber between,giving a maximum travel distance of approx 140mm thus lowering the trailer bed by up to 250mm therefore making the bed tiltable will eliminate the use of ramps,drive on ,drive off....in comparison tandem axle assy with elec brakes approx $1800 ..... irs with brakes approx $1400,,i will need to start building soon so to get the car to different locations for work to be done that is outside my ability
,i have completed brakes assy,steering assy and fitted lights,f&r bumper and overriders,boot and bonnet locks and stays ,rollbars ,wiring harness,body prep to 80%,engine bay almost completed for spray job,windscreen should be here next week sometime then its crunch time 290 or 260
HMMMMM but definetly 6 speed manual
,,anyway your trailer looks good are you thinking about a canvas cover for wet weather,or just praying.
darrell
