The replacement clutch slave cylinder for a Superformance Coupe can be obtained from your local Mazda dealer or even a NAPA dealer. The replacement is for an earlier Miata. Note that you might want to be sure that the bleed valve is on top (not on the bottom as shown in your picture) That way you can be sure no air is entrapped in the system when you bleed it! Also check (if this coupe is equipped a six speed) that the actuating rod is not a piece of threaded rod! Contact BRE for the right bracket and rod. Badger
