Old 08-08-2007, 09:52 AM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Default Cautions when welding
I'm having a friend weld up the support brackets on the side pipes over the weekend. They broke half way down the length between the side pipe and the rubber body mount. He owns a welding shop and said he would decide what type of welding to do once he crawls under the car. I told him they were ceramic coated.
What cautions should I do for the Cobra?
Just disconnect the negative ground cable at the battery?
What about the stock Ford Duraspark ignition module?
Warren
