Old 08-10-2007, 02:08 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Rick,
Here are a few items to check. I know I am no expert with the webers at least you can try a few things.
1) Make sure the throttle for that cylinder is seat correctly. Sometime these throttle plates are slightly opened which will not create enough vacuum to draw the fuel.
2) Make sure your carbs are properly synced. You mention that they are quite close with syncronization but they should be close to exact.
3) Pull the jets and make sure you are getting fuel in the bowl where the jets sit.
Note: I am assuming you have already checked that you are receiving spark.
Are the plugs wet with fuel ?
