convincor: Approximating the I.D. from the as-cast O.D., I'd say it probably has a .875" bore, 1.0" at the most. Trouble is, if I improve the front calipers to 2-piston floating pin type, I might need the fluid volume displacement of a larger diameter master cylinder.
