For gosh sakes,
What does a girl know about Racing? Shouldn't there be a filter to keep them from posting on "All Racing Talk"?
K, you know I'm pulling your leg,
you drove away from Tulsa while I pushed...
Bruce, I contacted Wilwood and asked them about what pad I should upgrade to for the track. I got the more agressive pads (front only), installed them myself (easy!) , and wow, what a difference!
Their opinion is we don't need 6 piston calipers, factory is fine - the car's just don't weigh enough.
Slotted helps cooling more than drilled. Not as cool looking, but performance only. I also redirected my footbox cooling ducts to the brakes for fresh air cooling.
Good luck and I'll see you in my rear view at Motorsport!
